justwondering01
Oct 13, 2015Aspirant
Genie app won't connect to OpenDNS
I am trying to useGenie Parental controls and when I attempt to login to my OpenDNS I get the following error "There was an error signing, in please make sure you're connected to the Internet and tr...
- Nov 02, 2016
Got it to work! In the end, it looks like the router did not reset properly when it was shut down. So I unplugged it, then put the power switch to on/of 4 or 5 times (to discharge the capacitors), then plugged the power cord back in. Once fully booted, the Genie app was able to talk to the router on the first try. What is wierd is that in the last weeks, all other devices must have contuinued to work with the Genie app since Parental Control/by-pass account was still working fine...
Weird one...
Anyway, thanks for your help Dexter! And I hope this is of use to someone... :)
kolbyjh
Oct 29, 2015Aspirant
I'm having the same issue with R6400. I have tried using the Netgear Genie app from Windows 7, iPad 2 with iOS 9.1, and iPhone 5s with iOS 9.1. On Windows I get the error message specified in the original post. On the iPad and iPhone the app usually crashes when attempting to configure the parental controls and logon to openDNS.
DexterJB
Oct 30, 2015NETGEAR Moderator
Hi kolbyjh, johnathome, rock_roller, and moytyler,
You should be able to login to your OpenDNS account through the NETGEAR Genie and manage your LPC (Live Parental Controls) settings.
Dexter
Community Team
- justwondering01Nov 01, 2015Aspirant
I tried again from my desktop and got the same error but I was able to download the app on to my iPhone and it worked like it was supposed to. I will try removing the software from my desktop and reinstalling it. Thanks for getting this fixed.
