LisaWar
Mar 29, 2017Aspirant
genie app
im so frustrated. im trying to log into the Geni app on my Samsung Galaxy S5 and it wont let me. it says to log in with the user name (which has 'admin' already filled in) and password. all of whic...
LisaWar
i logged into netgear, then it went to the next login. thats the one i cant get into.
michaelkenward
Mar 29, 2017Guru - Experienced User
LisaWar wrote:i logged into netgear...
What does that mean? Netgear what?
Forget about the genie. First use your Samsung to access the wifi. Mess around a bit to confirm that you have wifi access.
Then start the Netgear Genie.
Then login with the default details user = admin (you cannot change that) and password = password. If password does not work, then you, or someone, may have changed the password using the browser interface.
We don't actually know what you are trying to login to with the genie. I assume a Netgear router, but which one?
- JYurtApr 23, 2017Tutor
not sure if related, installed configured PARENTAL CONTROL...and am trying to DISABLE, which apparently I need GENIE for
(im ok NOT usesing GENIE)
the darn app wont login with with ADMIN, which or course isnt the issue when logging into 192.168.1.1 (router)
i really want to DISABLE controls, (as this isnt what i was looking for, BLOCKING isnt what i want, i want to 'see' what / where the kids are going, who they are IM'ing..etc..)
anyway...please help me get back into GENIE or DISABLE my PARENTAL CONTROLS so i dont use your DNS anymore
thank you in advance
Hardware Version R8000
Firmware Version V1.0.3.36_1.1.25
GUI Language Version V1.0.3.36_2.1.49.1
- michaelkenwardApr 23, 2017Guru - Experienced User
Try using the web interface, your browser, to set up your router.
