LisaWar
Mar 29, 2017Aspirant
genie app
im so frustrated. im trying to log into the Geni app on my Samsung Galaxy S5 and it wont let me. it says to log in with the user name (which has 'admin' already filled in) and password. all of whic...
JYurt
Apr 23, 2017Tutor
Goal is to disable parental controls.
Can only do that from GENIE APP
michaelkenward
Apr 23, 2017Guru - Experienced User
It works through the web browser here.
Unless you have changed it, the password for the web interface is password. That will work whatever you use to access the router.
The manual explains how to do this:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
See page 54.
You need the genie to bypass your default settings.
