LisaWar
Mar 29, 2017Aspirant
genie app
im so frustrated. im trying to log into the Geni app on my Samsung Galaxy S5 and it wont let me. it says to log in with the user name (which has 'admin' already filled in) and password. all of whic...
JYurt
Apr 23, 2017Tutor
Appreciate the call out.
I know how to do, it, I just can't get logged in.
And password doesn't work
- DexterJBApr 25, 2017NETGEAR Moderator
Hi JYurt,
1. Have you tried using another device (iOS, Android, PC, Mac)?
2. Please make sure you are using the correct router logins.
3. Have you tried resetting the router?
Dexter
Community Team
- JYurtApr 25, 2017Tutor
Hi Dex...thanks fo the suggestions...
indeed all of the above and NO LUCK
have tried from DRIOD, IOS, Windows...
its that darn GENIE, 'app' can't get past the login...just SPINNS...SPINNS...
i just want to be able to DISABLE PARENTAL
its frusttrating, i can't UNDO the DNS entry...
ARGH!!
