LisaWar
Mar 29, 2017Aspirant
genie app
im so frustrated. im trying to log into the Geni app on my Samsung Galaxy S5 and it wont let me. it says to log in with the user name (which has 'admin' already filled in) and password. all of whic...
DexterJB
Apr 25, 2017NETGEAR Moderator
Hi JYurt,
1. Have you tried using another device (iOS, Android, PC, Mac)?
2. Please make sure you are using the correct router logins.
3. Have you tried resetting the router?
Dexter
Community Team
JYurt
Apr 25, 2017Tutor
Hi Dex...thanks fo the suggestions...
indeed all of the above and NO LUCK
have tried from DRIOD, IOS, Windows...
its that darn GENIE, 'app' can't get past the login...just SPINNS...SPINNS...
- JYurtApr 25, 2017Tutor
i just want to be able to DISABLE PARENTAL
its frusttrating, i can't UNDO the DNS entry...
ARGH!!
- DexterJBApr 26, 2017NETGEAR Moderator
Hi JYurt,
You can disabling/setting the filtering level to None by logging in to https://netgear.opendns.com/sign_in.php.
Dexter
Community Team
