Noneofurbusines
Apr 18, 2017Tutor
Genie App
Can I use the Genie app to test wifi speed to the router? (Not internet, I'm trying to isolate a slow connection, my ISP says their DSL is working perfectly.)
michaelkenward
Apr 19, 2017Guru - Experienced User
Maybe you could tell people what hardware you want to test.
Wifi speed from what to the router?
- mondenathApr 19, 2017Prodigy
Yes you can .
Just connect an USB 3.0 pendrive and copy say 200-500Mb files and try to copy via turbo transfer which is the fastest transfer that can be made via all available channels at maximum bandwidth.
if you are say able to transfer upto100mb+ or 12MB/s then you are good to go. As most phone might struggle more than 100mbps unless its octo core
