Showsome
Apr 27, 2017Apprentice
Genie app
I just updated my R8000 Nighthawk router and ever since my genie app will not stay logged in. I can login into my routert through routerlogin.net but not through the app on my phone or computer. I un...
Showsome
Apr 29, 2017Apprentice
I have fixed my issue. I looked up Netgear R8000 firmware. I looked up an older version. Current version is V1.0.3.36.
I downloaded a zip file of V1.0.3.32 and opened zip file once it downloaded. Login to your router with router login.net go to router update and browse you're files for the install. Make sure the file ends with a chk.
- hefayedApr 29, 2017Aspirant
usually it works after the reboot and come back after multiple logins, did you try multiple times
