abuehrlen
Aug 03, 2014Tutor
Genie Apps not accepting router password
I get " Login Failed. Please re-enter the correct admin password for your NETGEAR router." I get that on both mobile and desktop versions of genie. Any help anyone can give would be greatly appreciat...
gartaud
Aug 03, 2014Aspirant
The Genie app does not work for me if IPv6 is enabled on the router. Did you enable IPv6 on the router by any chance? If so try disabling it.
