Ciccione
Sep 03, 2015Aspirant
Genie D6200: modify router LAN ip address gets UNDEFINED box
Hi all, I just bought a brand nw Genie D6200 , firmware version V1.1.00.14_1.00.14. In advanced LAN settings I need to change the default ip address reserved to the router eth interface (19...
Ciccione
Hi again,
I work in a Network Operation Center and my ip address is a static one.
For various reasons we all have a static address in our team.
Said that, I have 2 laptops, statically configured, that I want to use at home without making any change to the network device configuration every time I move those PC from office to home or from home to office.
Anyone else that wants to connect to my home network can easily and transparently get a dynamic adrress .
I mean , what we're talking about here is nothing weird, I should be free to confiigure any ip address I want as a default gateway on my home's router.
Anyway, the ip i s a /24,
DHCP is enabled and , as usual, starting and ending ips are .1 and .254, except, of course, .116.
This is definitely a bug,
What I enter in LAN setup page is nothing but the ip address that I want to be the default gateway of my LAN, that is 172.31.1.116/24.
If I enter 172.31.1.1 the router won't complain and save the config.
Otherwise, when I enter , as the last byte, any number different from .1 the "UNDEFINED" box comes up.
That's why I'm saiyng it's a bug.
There were no such issues on my previous Netgear routers.
TheEther
Sep 03, 2015Guru
It's still a bit odd to be using static addresses, even in a NOC. They could have used reserved IP addresses and handed them out using DHCP. Maintaining static addresses on multiple laptops is a maintenance nightmare. Oh well.
There's nothing wrong using whatever IP address you want for your home router. Anyway, I mean no offense, so I will refrain from commenting any further about the basis for your need.
What I suspect may be happening is this: the router is balking at the fact that .116 is in the middle of the range .1 through .256 set aside for the DHCP address pool. You are not supposed to assign your router an IP address that is inside the same pool of addresses that the router is handing out. Assigning .1 to your router works because it's smart enough to adjust the address pool to start from .2. Try it, you will likely see the starting DHCP address change automatically. It can't adjust the range when .116 is used because it would need to create two ranges, .1 to .115 and .117 to .256. Of course, they could have handled this transparently, but perhaps they removed the code in the D6300.
Try changing the DHCP ending address to .115. This should remove the conflict. This does imply that you can only have 115 devices at home. I hope that is not a problem. :smileyhappy:
I have another, unproven, hypothesis that Netgears don't permit the use of the private 172.16.0.0/12 subnet, but try the above change first. If it still doesn't work, then you may have proven my hypothesis.
