lennyr
Jul 17, 2014Tutor
Genie Destop Application Won't Let Me Log In
While I can administer the R8000 from the web interface, the Genie application (on Windows 8.1) won't let me log in, although the features that don't need an admin login seem to work. When I go to lo...
spikepol
Sep 25, 2015Aspirant
I've tried uninstalling and reinstalling genie several times to no avail, the router also has the latest firmware also the computer that is hardwired Will not let me log in. I have a kindle and a laptop that will log in, hence the firmware update.
DexterJB
Sep 25, 2015NETGEAR Moderator
Hi spikepol,
Please use this link to download another version of the NETGEAR Genie program and check if it gives the same error.
Dexter
Community Team
- spikepolSep 26, 2015Aspirant
thanks for the link but it still comes up with the same problem. Everything works really well, its just gets annoying that i cant log onto the router from my main computer, i have even tried to factory reset the router and that didnt work either. I even put the genie on my kindle and it works, i cant think of anything else to try and i would be grateful for any other sugestionsyou might have.
- Meo034Sep 28, 2015Aspirant
Have you tried changing the password back to the default password and see if you are able to login from your main computer? It is the only way I can access the wireless router :(
