BozeWolf
Mar 10, 2015Tutor
Genie doesn't work right with language set to Auto
There should have been nothing unusual about the incident: a burst of errors caused my router (a DGND3700v2) to lose its ADSL connection. It was just a one-off spike and as per usual, the connection w...
DexterJB
Sep 04, 2015NETGEAR Moderator
Hi BozeWolf,
The connection may have been reset from the ISP or a possible firmware glitch. I recommend doing a firmware reflash.
You can find the latest firmware using the link below:
http://downloadcenter.netgear.com/en/product/DGND3700v2#searchResults
Refer to the link below for the instructions:
http://kb.netgear.com/app/answers/detail/a_id/23960
Dexter
Community Team
