SteveL2013
Nov 20, 2013Follower
Genie for Mac OS Not Supported on 32bit CPUs?
I recently bought a used 3800 router and trying to get it set up. I downloaded the Genie for Mac OS application from the dpwnloads website, installed it but when trying to run the application, I get ...
justrluk
Jan 10, 2014Novice
netgear_user_ wrote: Same problem here:
Although it is possible to install Genie on Macbook 1,1 Intel Core Duo (32bit) with Mac OSX 10.6.8 [installation successful notification], when opening the application an error is shown:
"You can't open the application NETGEARGenie.app because it is not supported on this type of Mac."
I keep getting the same error. A fix for this would be welcome.
- dshiell55Nov 30, 2015Aspirant
Did anyone get this problem solved?
