rltbubba
Dec 16, 2015Follower
genie installer/updater not windows 10 compatable
i just installed new HP desktop with windows 10..............tried to install netgear genie app and boom loads then cant run.
is netgear working on a fix.
1 Reply
- Retired_Member
I stated in the last 3 post on the same subject. I have Win 10 64 Pro, I installed it after a drive format and my genie works fine. You might read through those post.
