Shznav
Apr 06, 2017Guide
Genie iOS app
Is anyone having trouble logging into the router from the genie app since the last firmware upgrade? No matter what I do I can't log into it. I also hate the new layout of the iOS app. Any help would ...
bro79
Apr 19, 2017Aspirant
I also have a netgear r8000 having the same issues not being able to log into the genie app on iphone, android and PC. The issue started right after the last firmware update.
I have tried the following and still the same
- Factory reset and restore of config
- Factory reset using stock config
- Power cycled unit many times
Still having the issue and seems like I'm not the only one with the problem.
guyguy
Apr 20, 2017Apprentice
BRO79~ You are going to have problems with this router and you will continue to have issues either with the router or Genie app. Why do you think I bad mouth this router and Genie app. Both are terrible and Netgear sucks. Like you, I bought the r8000 router based on Amazon reviews and other reviewers say how great this router is and it is powerful and a work of art. It is fast and blah, blah, blah. After about two weeks of using it, I was like what the hell, this is the same router that some people are saying is GREAT. I thought I made a mistake, I thought I bought the wrong router. Trust me, there is NOTHING great about this router. This is my opinion and it is based on using the stupid thing. My heads still spins around, thinking that Netgear dupes people into buying a 300 dollar router and give lame features. Netgear has some money deal with OpenDNS to provide the filtering process. In this case, you bought a paperweight.
