Shznav
Apr 06, 2017Guide
Genie iOS app
Is anyone having trouble logging into the router from the genie app since the last firmware upgrade? No matter what I do I can't log into it. I also hate the new layout of the iOS app. Any help would ...
Shznav
Apr 26, 2017Guide
Hey, thanks for the info. My default internal IP is set at that and I still have the issues. What router do you have? I have Nighthawk x6 R8000. And I tried the factory reset a bunch of times. The app then works once and then says log in failed after that. It says router not found check to see if connected to guest network (which I'm not) and make sure that IPv6 is disabled which it is. So I have no idea what the problem is. Also after doing the factory reset for some reason my speed went down on a wired LAN from 600 Mbps what I'm getting from my isp and then would top out at 450 Mbps. Makes no sense. Especially wired in with Cat5e.
mgbnet
Apr 26, 2017Guide
I have the R8000 too.
For the weird speeds, I found I had to disable Dynamic QoS to get the appropriate speeds. I did do some digging online and found a few folks with that same problem and disabling the Dynamic QoS seems to be the answer.
