Shznav
Apr 06, 2017Guide
Genie iOS app
Is anyone having trouble logging into the router from the genie app since the last firmware upgrade? No matter what I do I can't log into it. I also hate the new layout of the iOS app. Any help would ...
Shznav
Apr 26, 2017Guide
I had the same issue Dynamic QoS did the same thing to me. I'm just puzzled if this is a router issue or a cable modem issue from my isp. Do you put your cable modem into bridge mode and turn off the wifi settings on it? That's what I did. Still having the same problem.
mgbnet
Apr 26, 2017Guide
I don't have the cable modem my ISP normally provides. I use Comcast and the modem they provide is just dreadful. I returned that and bought my own. They're cheap enough! The one I purchased is a basic DOCSIS 3.0 modem, with no onboard WiFi: http://www.arris.com/surfboard/products/cable-modems/sb6141/
Not sure if that helps you, but that's my set up.
