Shznav
Apr 06, 2017Guide
Genie iOS app
Is anyone having trouble logging into the router from the genie app since the last firmware upgrade? No matter what I do I can't log into it. I also hate the new layout of the iOS app. Any help would ...
Shznav
May 12, 2017Guide
How do I roll back the firmware ? Thanks for you helping out! I appreciate it
- mstangMay 13, 2017Aspirant
Go to netgear.com and click on support. Enter your router model and click on downloads. There is a link for previous versions under the current downloads. Download firmware version ending in .32
Connect to your router and click on Advanced tab, then click Administration and Router Update. Click Browse and it will let you find the router firmware file you just downloaded. Click upload (I don't remember if you need to click anything after that but it should be self-explanatory).
BR/Mike
