hotsprout
Oct 17, 2013Aspirant
genie login/readyshare/newbie
newbie problem I have N300 CABLE NETGEAR ROUTER WNR2200, but I cant login via the genie software, however if I go via the ip route I can access the router page, also when I go to readyshare in the ...
jmizoguchi
Oct 17, 2013Virtuoso
With Cell Data and not WIFi correct on BB?
Connect to the USB Drive from a Remote Computer
To connect to the USB drive from remote computers with a web browser, you have to use the router’s Internet port IP address. If you are using Dynamic DNS, you can type the DNS name, rather than the IP address. You can view the router’s Internet IP address from the dashboard on the Basic Home screen or the Advanced Home screen.
Access the Router’s USB Drive Remotely Using FTP
To connect to the router’s USB drive using a web browser:
1. Connect to the router by typing ftp:// and the Internet port IP address in the address
field of Internet Explorer or Netscape Navigator, for example:
ftp://10.1.65.4
2. Type the account name and password that has access rights to the USB drive. The user
name (account name) for All – no password is guest.
3. The directories of the USB drive that your account has access to are displayed, for example, share/partition1/directory1. You can now read and copy files from the USB directory.
