hotsprout
Oct 17, 2013Aspirant
genie login/readyshare/newbie
newbie problem I have N300 CABLE NETGEAR ROUTER WNR2200, but I cant login via the genie software, however if I go via the ip route I can access the router page, also when I go to readyshare in the ...
Devor
Oct 18, 2013Luminary
Typically when you connect a modem/router combo unit and another router there will be issues unless they are connected properly.
I'm not familiar with the Sky, but you could either turn the Sky into a dedicated modem by placing the Sky into Bridge Mode and then use the WNR2200 as the primary router. You would have to log into the combo unit and see if you find the option or have your ISP make the change.
Or, use the Sky as the primary router and set up the WNR2200 as a secondary access point by following these instructions here. Skip step one.
