sarachan
Jan 08, 2017Follower
Genie Network Map -- blue / purple lines?
We have an R7000 Nighthawk router, and although we have 6-8 wifi devices in our home, we do want to minimize wifi signals as much as possible to mitigate any possible health risks, such as not having...
crsmith
Feb 26, 2017Aspirant
Pluto8 thanks for the info. I have not found a definition for Blue/purple lines. Can you or anyone else help?
schumaku
Feb 26, 2017Guru - Experienced User
crsmith wrote:Pluto8 thanks for the info. I have not found a definition for Blue/purple lines. Can you or anyone else help?
Anything different from the green ones (explained above) is blue/purple.
Updated Genie App on iOS and Android has already chanved this not very meaningful colour scheme - all white lines on blue background. Convinced the Windows/macOS Genie will follow soon.
