mfedorov
Aug 24, 2016Follower
genie not working now
WIndows 10 desktop, hardwired to router. I got the router yesterday. I set up 2 wifi networks, I saw the Network map, I set up my parental controls (there was only the option for "Medium" filteri...
DexterJB
Sep 01, 2016NETGEAR Moderator
Hi mfedorov,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- BrinybayJan 30, 2017Aspirant
I just installed a new modem and router today, but now the Genie software on my desktop is not working. When I click on it, I only get the blue spinning circle for a couple of seconds, then it just disappears. The router and modem seem to be working ok.
- DexterJBFeb 02, 2017NETGEAR Moderator
Hi Brinybay,
1. Please try uninstalling then re-installing the program.
2. Please try using another device (Android, iOS, another computer).
Dexter
Community Team
- BrinybayFeb 03, 2017Aspirant
Problem seems to have been cleared up by simply rebooting the computer. I did not install the Genie app on my smart phone because I don't see any reason to access it from there.
