rameshms
Oct 10, 2016Aspirant
Genie on iOS10/Iphone6 cannot login to R7000
Netgear genie on my Iphone6 running iOS10 doesnt login to router any more.
Keeps saying NETGEAR router is not found or is not supported etc etc etc.
I believe the problem may have started after i upgraded firmware version on the router. I'm not absolutely sure.
My netgear router is running below firmware version.
Firmware Version
V1.0.7.2_1.1.93
Sort By
I have similar issue and I explained my workaround here. see whether it works for you
The latest update of Genie 2.4.34 fixed the issue. The workaround is no longer needed. I guess it is something related to IOS10 (as mentioned in the release note of the Genie)
