jestercap72's avatar
jestercap72
Follower
Jan 21, 2015
Genie problem on ReadyShare
Hi,
sorry if it has been asked before.
Anyway, I am using the Genie app on two different Samsung Phones (Note 2 and S4).
On the S4 everything works fine.
On the Note 2, everything works except the ReadyShare section. There I cannot access the ExtSdCard of the phone from the file browser: if I tap on the SD icon it accesses recursively the Internal Storage of the phone.
All other apps access the ExtSD correctly. I have tried to uninstall and re-install the Genie app but to no avail.
Any idea? :confused:
A
1 Reply
  • If you are referring to DLNA feature of readyshare, make sure that you are connected on one network as will not detect DLNA devices connected to the router.
