thomasf
Dec 08, 2013Follower
Genie Problem
This may be the wrong place to discuss the Genie product but I would appreciate some help. Using Windows 8.1 through the Netgear D6200 to the Apple Airplay Express. The music drops are annoying an...
theoldfarter
Mar 04, 2014Aspirant
Installed it on another laptop running Windows 7 (x64) Ultimate.
Genie does not show in devices & printers. Does not show after a restart of laptop or a restart of the D6300.
On my Windows 8.1 (x64) laptop, I removed all instances on Genie except one.
Restarted the D6300 a couple of times but doing that did not add any more genie instances.
Restarted my 8.1 laptop & another instance of the Genie appeared in devices & printers. Every time I restart my laptop, another Genie icon appears.
It looks like there is an integration glitch.
I will wait until you reply & if no solution is forthcoming, I will email Netgear.
Thanks.
Thanks.
