thomasf
Dec 08, 2013Follower
Genie Problem
This may be the wrong place to discuss the Genie product but I would appreciate some help. Using Windows 8.1 through the Netgear D6200 to the Apple Airplay Express. The music drops are annoying an...
trainnut
Aug 18, 2015Guide
I have a 6300v2 with Genie 2.4.12 running on a Win 10 Pro 64 bit and another computer running Win 10 Home 32 bit plus an old XP machine used just for running my model trains. This did not happen when running Win 7 Pro on the one machine and Win 7 Home nor on the XP. This problem only showed up after upgrading the two machines to Win 10 (not much dissimilar from 8.0 or 8.1). I was getting many instances of the Genie Media servers like you, and I just now discovered what I think is the answer.
I don't give a rip about sharing media between cvomputers as I don't use my computers as toys but as serious tools. I guess that is not the norm these days (I am 73 and a retired IT who used computers as business tools, not playthings) and why NetGear sets the media servers on by default.
After deleting all instances on the two Win 10 machines (not showing up on the XP), I then opened NetGear Genie and by looking a little bit I found a setting I have never used because I never needed it with Win 7. Give this a try and see if it works for you as it did for me.
First delete all instance of the Genie Servers in Devices and Printers. If you don't, that is ok as you can delete them later, but they will show up in the next step if you don't delete them first. What you are going to do next is turn off the Genie Media Service within NetGear Genie. In the left column of choices click on 'My Media'. In the box to the right and at the top of that box you will see a square button and next to it a refresh button. When you point to the square, it will say something like 'turn off service'. Click on that and confirm. That turns off the media sharing service with Genie and should stop the annoying instances of media servers in devices and printers.
I believe that will solve the problem.
trainnut
Aug 19, 2015Guide
I did discover one other thing that all need to know, Of course, the simpleist solution is for Netgear to fix Genie so this doesn't happen. But, in the meantime, this solution does work with one caveat and that is if you restart the computer or shut it down and then start again, Genie will reset the service as on when it reloads. Just open Genie and turn it off and you will not get the repeated instances of Media Servers. You should only get one server for each computer on the network in Devices and Printers on each connected computer. If you put the computer(s) in sleep or hibernation, the service will remain off though and you do not have to turn it off again. You only have to do it for any computer(s) that were restarted or shut down.
