thomasf
Dec 08, 2013Follower
Genie Problem
This may be the wrong place to discuss the Genie product but I would appreciate some help.
Using Windows 8.1 through the Netgear D6200 to the Apple Airplay Express. The music drops are annoying and I have found that the problem may be exacerbated by the Genie software.
On the Windows page "devices and printers" there is an item "Genie Media Servers" and if I close out the system and then restart there will be two or "Genie Media Servers" and then three. The more replications of the Genie Media Servers icon the more the problem exist. When I delete all but one of the Genie Media Servers the system works fairly well.
What is this function and how does one control it?
Am I the first to have this problem?
Tom F
- jimsheila1AspirantI have the same problem. I uninstalled genie v16 and tried v13. The results were the same. When I restart, another genie media server icon is added. I uninstalled the genie app and cleared all the media server icons. I restarted several times and found more genie media server icons in the multimedia area of Devices and Printers, even with the genie app removed.
I did not have this issue until I updated to genie v16. So, I am assuming that the issue is a compatibility issue. Hopefully Netgear will resolve it. - DevorLuminary
theoldfarter wrote: No, I don't use it. It would be nice to have it working correctly with Windows 8.1 though.
Seems like you are investing a lot of time into something that you don't use. :)
I can understand if you're bored and need something to do, but to be honest, it's always been a buggy program that wastes CPU cycles. - theoldfarterAspirantHa Ha ... you are quite right. It has now been uninstalled. Thanks all :)
- SuRFDownUnderAspirantI have Genie installed because I use Bypass accounts on the Parental Control. Is there a different program I can run to handle the bypass accounts without needing Genie?
- DevorLuminaryHave you tried accessing the router's configuration with a web browser?
- SuRFDownUnderAspirantYes, but that does not help. For override accounts to work you need to have a program (Genie) running on the machine. The problem is that is all I need. I do not use Genie for anything else. What I want is a program that enables the Bypass account, but does not suffer from the Genie bug of creating a zillion multimedia devices.
- theoldfarterAspirantDoes Netgear see these posts of ours?
- DevorLuminary@SuRFDownUnder
Sorry, I have no experience in that area. If it's any consolation, the desktop Genie software, regardless of the version, is buggy and in my opinion, a waste of cycles. Can't say whether it will help or not, but have you seen this here?
@theoldfarter
At it's core this is a user-to-user forum. To contact Netgear support, click here. - theoldfarterAspirantHave emailed Netgear about this, will update as to what happens.
- theoldfarterAspirantFind myself with time on my hands so installed Genie v2.3.1.12 again. Will keep an eye on how many installs it does in Devices & Printers, as I think I was mistaken when I previously said v12 did not generate icons in there.
