Chromag9
Oct 24, 2016Aspirant
Genie R6200v2 - Botnet Vulnerability on Port 7547
Could someone at Netgear explain to me why port 7547 is open to the outside internet? This port is for CPE WAN Management Protocol (CWMP), apparently. I have remote management turned off. Due to t...
DexterJB
Oct 30, 2016NETGEAR Moderator
Hi Chromag9,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Chromag9Nov 01, 2016Aspirant
Hi Dexter. Sorry for the delay. I used the following site posted on Lifehacker about testing your network for possible IoT vulnerabilities:
http://iotscanner.bullguard.com/
I retested my network this evening and it's saying I'm protected and port 7547 is no longer showing up. A bit odd that it was showing up and now it's not.
I'm using the Genie R6200v2. Firmware AV1.0.3.10_10.1.10. When I check for updates it says I'm running the latest version.
Thanks!
