etwasetwas
Jan 13, 2017Follower
Genie Remote Access C6300BD Android not showing Login menu
I have searched the support areas for a solution to the problem I'm having, but I've been unable to solve this issue I have with gaining Remote Access on my Droid Maxx device. The link above displays identical issues to the problem I'm having. There's no menu to tap in the Login area that allows me to "Login as Remote access". Can someone identify the appropriate solution to this issue? I've checked for updates on the firmware, installed the newest version of the software on my phone, and still cannot solve the issue.
Thanks in advance
Hi etwasetwas,
Your device model number is currently not supported. The supported devices are listed below.
DSL Gateway AC (1)
D6400Wireless AC Router (2)
R6250
R6400Wireless AC Router NightHawk (10)
R6700
R6900
R7000
R7300DST
R7800
R7900
R8000
R8300
R8500
R9000Regards,
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi etwasetwas,
DSL Gateway AC (1)
R6250
R6700
R6900
R7000
R7300DST
R7800
R7900
R8000
R8300
R8500
R9000Regards,
Dexter
Community Team
