Beavis1026
Aug 26, 2016Follower
Genie router
I have Verizon fios and I was wondering get if I could use the new Genie router to make my wireless speeds faster. I don't know if you can use a router with a cable modem, or if net gear has something...
DexterJB
Aug 28, 2016NETGEAR Moderator
Hi Beavis1026,
Most, if not all, NETGEAR routers work with Verizon FiOS modems or modem-router's so that should not be an issue. If you are not getting your subscribed speed from your ISP's device then I recommend contacting them and make sure everything is fine on their end and on your device.
Here is the link for the NETGEAR home routers:
https://netgear.com/home/products/networking/wifi-routers/?cid=wmt_netgear_organic
Dexter
Community Team
