DLSchmidt11
May 26, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
DexterJB
May 29, 2017NETGEAR Moderator
Hi DLSchmidt11,
Have you tried uninstalling and re-installing the app then going through the backup setup again?
Dexter
Community Team
- DLSchmidt11May 30, 2017Tutor
Thanks for the feedback Dexter. I did as you suggested and unintstalled, then re-installed the ReadyShare Vault application on my Windows XP desktop Dell computer. This cleared the error. I then modified the backup settings (frequency and max storage size) and started a new backup. This new backup ran to 99% complete (1 item remaining) and again triggered the repetitious "unspecified error" message. Again the error will not clear when acknowledged. I subsequently rebooted the PC and the error message returns. I re-opened the ReadyShare app, which still showed 99% complete, then paused and resumed the backup. The backup status now indicates 100% complete, but the error meesage persists.
I have also since installed ReadyShare Vault on my new Windows 10 Dell laptop and sucessfully ran a backup with no error messages. Do you have any other ideas regarding the "unspecified error" message that continues on my Windows XP machine?
Darrell
