DLSchmidt11
May 27, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
DexterJB
Nov 15, 2017NETGEAR Moderator
Hi myryde77,
The case is currently being worked on. We will provide an update once available.
Dexter
Community Team
myryde77
Nov 16, 2017Star
Hi DexterJB,
I installed the latest versions of Genie and Readyshare vault on a different PC running windows 10 as well and it worked just fine. I am guessing this issue we are seeing is with the update process from one version to the next. Since uninstalling and reinstalling doesn't fix the issue, could it be that the uninstall doesn't remove everything it needs to? Could you provide any insight on what else we may want to delete in order to get a fresh install?
