DLSchmidt11
May 26, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
dprice03
Dec 01, 2017Aspirant
Hello I am also getting this annoying error message (Genie Timelline Unspecified Error). From reading through the posts, simply uninstalling it does not work. PLEASE let me know how to PERMANENTLY remove this annoying error message. Thank you!
myryde77
Dec 01, 2017Star
Install the old version. The new one won't work
- evandeneFeb 14, 2018AspirantI have the same problem. Genie Timeline error (Windows 10) From where can I download the old version? I found a link somewhere but that didn't work anymore
- Retired-04Feb 22, 2018Aspirant
Have the same problem, installed latest firmware and genie app today, clean un-install, and re-installl. did not fix. ended up uninstalling Ready Share.
- evandeneFeb 22, 2018AspirantDear
Try to switch off your firewall program.
When I switched off my firewall program and used the windows 10 firewall all wend well
