DLSchmidt11
May 26, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
dprice03
Dec 01, 2017Aspirant
Hello I am also getting this annoying error message (Genie Timelline Unspecified Error). From reading through the posts, simply uninstalling it does not work. PLEASE let me know how to PERMANENTLY remove this annoying error message. Thank you!
myryde77
Dec 01, 2017Star
Install the old version. New one won't work
- Thompa3642Dec 16, 2017Tutor
Hi ,
I am experincing teh same issues.
Where do I download the old version from?
My R6700v2 disconnects from the internet every day and it seems this generates the error message in the GenietimeLine error... or coud it be the other way around?
Anyway, can you please advise to remove this annoying error? I have to switch of my speakers - which has other consequences!
thanks in anticipation,
Allan
- myryde77Dec 17, 2017StarYou have to contact netgear to get the old version. Good luck as that takes some time and asking the right questions. Once they get you the old version, it still won't upload all your files for some reason. They will then send you in a loop to keep re installing the app, which doesn't help. If I had more time I would continue trying their steps, but I know it won't help after multiple attempts. Old version at least doesn't give an error. Best of luck.
- Thompa3642Dec 17, 2017TutorThanks for replying.
Disappointing.
