DLSchmidt11
May 27, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
myryde77
Dec 17, 2017Star
You have to contact netgear to get the old version. Good luck as that takes some time and asking the right questions. Once they get you the old version, it still won't upload all your files for some reason. They will then send you in a loop to keep re installing the app, which doesn't help. If I had more time I would continue trying their steps, but I know it won't help after multiple attempts. Old version at least doesn't give an error. Best of luck.
Thompa3642
Dec 17, 2017Tutor
Thanks for replying.
Disappointing.
Disappointing.
