DLSchmidt11
May 26, 2017Tutor
Genie Timeline Unspecified Error
Getting an "Unspecified error" from Genie Timeline resident App that keeps repeating every second with annoying sound. Acknowledging the error pop-up window does not clear message because it keeps re...
myryde77
Dec 01, 2017Star
Install the old version. The new one won't work
evandene
Feb 14, 2018Aspirant
I have the same problem. Genie Timeline error (Windows 10) From where can I download the old version? I found a link somewhere but that didn't work anymore
- Retired-04Feb 22, 2018Aspirant
Have the same problem, installed latest firmware and genie app today, clean un-install, and re-installl. did not fix. ended up uninstalling Ready Share.
- evandeneFeb 22, 2018AspirantDear
Try to switch off your firewall program.
When I switched off my firewall program and used the windows 10 firewall all wend well- gearheadguyJul 23, 2018Aspirant
23Jul2018
R7000 sn: 100-20676-01R19
V1.0.9.34_10.2.36
I too have the following problem after ReadySHARE setup and it is on an up to date Windows 10; x86, 32 bit installation. What is the solution that has been applied to others that have had this same issue?
Dialog box on Windows home screen -
With Incessant beeping I can only stop by killing Timeline process until next time it launches.
Error msg as shown in ReadySHARE Vault
Your first backup did not
href="GSCOMMAND:ACT
first backup now</span
