richegeland
May 29, 2017Aspirant
Genie Timeline Unspecified Error
Not sure why, but this error message keeps popping up. I can get rid of it temporarily by ending it with task manager.
DexterJB
Jun 08, 2017NETGEAR Moderator
Hi richegeland,
1. Are you referring to the ReadySHARE Vault program?
2. Have you tried uninstalling and re-installing the program?
3. Does the issue persist on your other Windows device/s?
Dexter
Community Team
richegeland
Jun 09, 2017Aspirant
Yes, it is the ReadyShare Vault Program that evidently caused the "Genie Timeline" "Unspecified Error". I uninstalled ReadyShare Vault and the error message finally disappeared.
I have not tried to re-install yet, but will update when and if.
Thanks for your input.
Rich
