Badawin's avatar
Badawin
Genie Web UI WNDR3700v3 not showing correctly
I'm curious if anyone has seen their UI do something like this before. More importantly if anyone knows how to correct it that would be great. With iut like this some of the functionality isn't worki...
  • mediatrek's avatar
    Mar 27, 2017
    By chance do you have any Kaspersky 2017 security products installed? I know the 2017 product line has casued this kind of webGUI display issues just like this. Disabling the Kaspersky 2017 product does not work to correct the issue, you end up having to uninstall the Kaspersky product and the webGUI display issue is no more.
