Badawin
Mar 27, 2017Aspirant
Genie Web UI WNDR3700v3 not showing correctly
I'm curious if anyone has seen their UI do something like this before. More importantly if anyone knows how to correct it that would be great. With iut like this some of the functionality isn't worki...
- Mar 27, 2017
By chance do you have any Kaspersky 2017 security products installed? I know the 2017 product line has casued this kind of webGUI display issues just like this. Disabling the Kaspersky 2017 product does not work to correct the issue, you end up having to uninstall the Kaspersky product and the webGUI display issue is no more.
Badawin
I actually installed those about 2 days ago. I guess that's what I get for finally getting away from Norton.. hah.
I guess I'll have to hunt through the Kaspersky forums to see if I can hunt down a fix.
Thanks!
mediatrek
Mar 28, 2017Virtuoso
If you do not have Windows 10, but an older version of Windows OS, you can use you Kaspersky license and install the 2016 product version (see http://usa.kaspersky.com/downloads/software-upgrades/). The version 2018 product line is due out very soon. I installed the 2018 pre-release build version of Total Protection, and did not have the issue in the 2018 version.
