yyg36's avatar
yyg36
Genie with remote access - D7800- Does it support?
My device is Netgear D7800 Modem/Router.   Does it support Genie with remote access? I have trouble with  remote access from genie.   I found R7800 model is not support this function. How about D...
  • DexterJB's avatar
    DexterJB
    Feb 08, 2017
    Hi marson,
    1. Please try using another device (Android, iOS, another computer) to register the device.
    2. Please try resetting the router.
    3. If the issue persists, please try re-flashing the firmware then reset and reconfigure the router.
    Dexter
    Community Team
