yyg36
Sep 27, 2016Aspirant
Genie with remote access - D7800- Does it support?
My device is Netgear D7800 Modem/Router. Does it support Genie with remote access? I have trouble with remote access from genie. I found R7800 model is not support this function. How about D...
DexterJB
Oct 03, 2016NETGEAR Moderator
Hi yyg36,
The remote login feature through the NETGEAR Genie app is currently not supported by your device.
Dexter
Community Team
yyg36
Oct 03, 2016Aspirant
Hi DexterJB
Thank you for your reply.
However, after checking the Netgear page on the compatiability of the D7800 Firmware Version 1.0.1.10,
it is clearly stated that the genie remote is supported by my device (D7800). I hope you can resolve this issue as soon as possible.
Thanks in advance,
Ryan Lim
I've attached the link and the captured image below:
http://kb.netgear.com/app/answers/detail/a_id/30960?cid=wmt_netgear_organic
