yyg36
Sep 27, 2016Aspirant
Genie with remote access - D7800- Does it support?
My device is Netgear D7800 Modem/Router. Does it support Genie with remote access? I have trouble with remote access from genie. I found R7800 model is not support this function. How about D...
DexterJB
Dec 21, 2016NETGEAR Moderator
Hi msimms,
The OP's issue has been resolved and he was able to make use of the remote login feature of NETGEAR Genie with his D7800. Please make sure you have gone through the setup process. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
msimms
Dec 21, 2016Aspirant
Hi Dexter,
Thanks for getting back to me.
I've followed the steps from the link you sent. At step 10 it requires you to register. This doesn't work. I get a message "The registration process failed try again?"
I've logged out and tried again, used a different computers to attempt the process. The result is the same.
Is there away to manually register the router?
Thanks
Mark
- msimmsDec 21, 2016Aspirant
Update: Retried registering using my phone (Android) and was able to register and can now access using Genie, at least from my phone. Not yet tried remotly with PC.
- DexterJBDec 22, 2016NETGEAR Moderator
Hi msimms,
Thank you for providing an update. Remote login should work on all your devices since you already have the device registered. Please keep us posted if there are any issues.
Dexter
Community Team
- il_maino84Jan 27, 2017Aspirant
Hi all.
I've the same problem with the last firmware (V1.0.1.16)
When i try to connect the remot access, i've this answer
If i try with the mobile phone the result is same.
Any idea?
Thanks
Regards
