yyg36
Sep 27, 2016Aspirant
Genie with remote access - D7800- Does it support?
My device is Netgear D7800 Modem/Router. Does it support Genie with remote access? I have trouble with remote access from genie. I found R7800 model is not support this function. How about D...
marson
Feb 07, 2017Aspirant
I'm having the same issue too
DexterJB
Feb 07, 2017NETGEAR Moderator
Hi marson,
1. Do you have the same model (D7800)?
2. What error message are you getting?
3. What are the steps that you have tried?
Dexter
Community Team
- marsonFeb 08, 2017Aspirant
I have the r6400, when i try to register it says " The registration process failed, try again
- DexterJBFeb 08, 2017NETGEAR Moderator
Hi marson,
1. Please try using another device (Android, iOS, another computer) to register the device.
2. Please try resetting the router.
3. If the issue persists, please try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
