yyg36
Sep 27, 2016Aspirant
Genie with remote access - D7800- Does it support?
My device is Netgear D7800 Modem/Router. Does it support Genie with remote access? I have trouble with remote access from genie. I found R7800 model is not support this function. How about D...
DexterJB
Feb 08, 2017NETGEAR Moderator
Hi marson,
1. Please try using another device (Android, iOS, another computer) to register the device.
2. Please try resetting the router.
3. If the issue persists, please try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
