Rogerhtml's avatar
Rogerhtml
Follower
May 22, 2017
Getting blocked
I have 4 teenagers which use the wifi alot. I sometimes block them if they don't do their homework. But sometimes they end up blocking me, is there a way so they can never block me if they are unblocked.
1 Reply
  • What do they connect to? (The modem/router?) And how do they connect? Wifi? LAN (wired)?
    Have you set up wifi security?
    If so, how? With passwords?
    Does your hardware support "parental controls"? (The manual should tell you that.)
