uptownvideo
Mar 07, 2025Apprentice
Guest Network in Nighthawk App
When I use the Nighthalk app to manage my CAX80 router I cannot see which devices are on the guest network. I can see all of the devices connect to the network but I want to see who is on the the gu...
uptownvideo
I am aware of the web interface. I was hoping that the app would have more information easier to use. I was wrong. It is full of adds to upgrade.
Mar 07, 2025Guru - Experienced User
What FW version is loaded on the CAX80?
What brand and model# devices do you have in the GN?
Try putting one of your devices in the GN with the MAC address randomizer disabled on it. Check to see if it appears on the CAX web page then check the NH app on a mobile phone or pad.
I recommend disabling any MAC address randomizer while at home.
- uptownvideoMar 07, 2025Apprentice
Firmware version of the CAX80 is 1.1.8. I know that it is old, but it has been working just fine and I am hesitant to update something if it is working. I will probably update it this weekend if the update is worth it. Most devices on the guest network are a macbook, dell laptop, blink cameras.
- FURRYe38Mar 07, 2025Guru - Experienced User
Is there a 5 in front of the 1.1.8? CAX80 never had anything that old on it.
My mistake. I was looking in the web interface and thought that was the letter S. It is version 5.1.1.8
