Cupcakesbaby_1
Jul 20, 2019Follower
Having signal issues with my netgear AC1750 .
Hello
Need help. Some of my devices are not connecting to router or the ones connected are in and out
1 Reply
Sort By
Tell us more.
What devices? Not connecting how? Wifi? Wired?
Cupcakesbaby_1 wrote:
... or the ones connected are in and outWhat does that mean?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?Is the Nighthawk App involved in this?
You might get better and quicker replies, and find other answers, over in the appropriate section:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
