imis999
May 23, 2022Aspirant
Having trouble with my CAX80 and XFinity
Hi, I have been having some issues with XFinity and my CAX80 modem/router. They rebooted it and it solved the streaming issue, but now the CAX80 doesn't show up in the Netgear mobile app as avai...
May 23, 2022Guru - Experienced User
Turn OFF the RAX120 to see if the NH app will connect to the CAX80
- imis999May 23, 2022Aspirant
ok, I will try tonight. The RAX120 was actually the trouble with the Xfinity streaming issue. It had to be rebooted at the same time the CAX80 was rebooted to get the Comcast to work.
