EJMack
Feb 11, 2017Tutor
Help setting up my router
I'm having a hard time setting up this router to my IMAC computer. Every time I try to log into my routerlogin I keep getting the message: You are not connected to your WIFI router network. But I am....
Feb 11, 2017Guru - Experienced User
Is the ethernet cable from the modem connected to the internet port of the router?
Can you give us the router model?
Also, can you let us know the IP address assigned to the mac (generally it will be 192.168.1.x or 10.0.0.x). There is guide that includes mac pc's here: https://kb.iu.edu/d/aapa
EJMack
Feb 11, 2017Tutor
I had the ethernet cable connected from the router to the techicolor modem.
