JoeUtica
Nov 13, 2016Tutor
Hidden Network
I recently noticed a Hidden Network as well as my Netgear Network displayed. All the other networks in my neighborhood no longer display. This is true only on my laptop. All other devices laptops in ...
- Retired_MemberNov 16, 2016
yes
Retired_Member
Nov 13, 2016Are you NOT broadcasting your SSID?
- JoeUticaNov 13, 2016Tutor
I believe I am broadcasting my SSID.
- DexterJBNov 15, 2016NETGEAR Moderator
Hi JoeUtica,
Please verify if your SSID is being broadcasted or not by accessing the router UI and checking the wireless settings. Once you have confirmed that it is, you can try forgetting all the network/s on the laptop and try scanning for wireless networks again then reconnect to your wireless network.
Dexter
Community Team
- Retired_MemberNov 15, 2016
turn off the router if the hidden disappears then you'lll know
