be_zwe
Nov 04, 2016Aspirant
How can I make the parental control filter work separately on different devices?
Hi Everyone! I had tried looking for an answer prior to posting this question. If I missed something, by all means you can point me to the right direction. I would like to limit my son from ...
- Nov 28, 2016
Hi DexterJB,
Thank you so much for all the help. I found the solution to the problem!
I found out that not ALL categories under the "High Filter" are being blocked. Exactly the main reason why my son could still access the internet. Therefore, I chose the "Custom Filter" and checked every single one of them. Whoala!
Again, thanks!
Br,
B
DexterJB
Nov 14, 2016NETGEAR Moderator
Hi @be_zwe,
1. Does the "High" filter work for your devices if you don't login to your bypass account?
2. Have you tried setting the default filtering level to "High" or any other level other than "None" to test if the filtering works? If not, please do so.
Note: Filtering may not take effect immediately since it is DNS based. Please give about 30 minutes to an hour.
Dexter
Community Team
- be_zweNov 18, 2016Aspirant
Hi DexterJB,
The "High" filter worked...with my husbands device (android)...but, not with mine(iPhone). He was being blocked from a couple of websites.
Overall, my son can still use the internet 24/7. :-(
Perhaps, the router itself has some defect/technical problems?
Thanks,
B
- DexterJBNov 22, 2016NETGEAR Moderator
Hi @be_zwe,
If you want to block your son's Internet access on a specific schedule you can do Address Reservation for his device/s and set a specific range of IP then block all services on a set schedule. You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24054
http://kb.netgear.com/app/answers/detail/a_id/24055
Dexter
Community Team
- be_zweNov 28, 2016Aspirant
Hi DexterJB,
Again, thanks!
Br,
B
